Used when ospf interface fails to enter into restarting helper mode %interface%: vlan name %reason% : reason for the failure
If reason indicates that helper is not configured, then configure the helper on the vlan. Otherwise no remedy required.
Info
OSPF interface %interface% fails to enter restarting helper mode due to %reason%.
| Name | Type |
| interface | String |
| reason | String |
